light bulb question
I was working on my head lamp assembly last night and noticed that the small bulb on the headlight assembly is out. I disconnected it, and the bulb itself seems fine, but the connector is corroded out, probably from condensation getting inside the lamp assembly, which is why I worked on it in the first place.
I've had no luck finding the plub for this small light. What is it called? (I've heard sidelight, but not sure that's accurate.)
Any thoughts?
thanks,
Any thoughts?
thanks,
1998 LAND ROVER Discovery
High & low beam headlamp
9003
9003ST Silverstar High Performance Lighting: the whitest and brightest Halogen
9003XV XtraVision Halogen Upgrade: Up to 30% Brighter
9003CB Cool Blue Halogen Upgrade: White Hot; Super Cool; 100% Street Legal
Parking light
2825
Front turn signal
2825
7506
7506LL Long Life Upgrade: Up to twice the life of the standard lamp
Rear turn signal
7506
Tail light
5007
7528
Stop light
7528
High mount stop light
7506
Fog/Driving light
H3-55W
H3ST Silverstar High Performance Lighting: the whitest and brightest Halogen
License plate
6418
Back up light
7506
Front sidemarker
2825
Rear sidemarker
5007
Glove box
6418
Map light
DE3175
Dome light
DE3175
Step/Courtesy light
6418
Trunk/Cargo area
5008
9003
Parking light
2825
Front turn signal
2825
7506
Rear turn signal
7506
Tail light
5007
7528
Stop light
7528
7506
Fog/Driving light
H3-55W
License plate
6418
Back up light
7506
Front sidemarker
2825
Rear sidemarker
5007
Glove box
6418
Map light
DE3175
Dome light
DE3175
Step/Courtesy light
6418
Trunk/Cargo area
5008
Also when you figure out which one it is you need, I can convert the part # so you can get it from anywhere, including wal-mart. Every bulb in our D1's is a common bulb.
so mike, are you a living Chilton's manual or something? lol
ORIGINAL: 05LandRover
the light bulb thing i found all the info on the net awhile ago when i need it.
Classklown90
Aug 21, 2010 07:24 PM
