Lining up the lower intake - injector ports are partially blocked?
Old Dec 2, 2016 | 07:09 PM
Jeff Blake's Avatar
Default Lining up the lower intake - injector ports are partially blocked?
I have a question on installing the lower intake manifold.
Check out this picture
Quite a bit (5-8mm) of the head is blocking the injector port. Is this normal? I can't think of any variables here except for decking the block/head, but I only had a few thousandths removed and can't imagine that making this big a difference
It's the same on both sides, and aligned correctly to the bolt holes
Old Dec 2, 2016 | 08:06 PM
LR03NJ's Avatar
I did not notice that upon our installation. We replaced all injectors. Im thinking that the injectors are flat and wont reach that indentation anyway. Also the rectangular opening below will only allow spray from injectors, IMO.
DBVintageAS
Apr 4, 2016 08:36 PM
jasile
Dec 20, 2014 07:25 AM
ara25
Mar 8, 2011 06:52 AM
salve7
Nov 26, 2008 11:06 AM
rwp389
Oct 18, 2007 06:58 AM
