View Poll Results: Use Dexcool (Orange) or Green (Universal) as Coolant/Rad. Fluid/Antifreeze in Disco2?
Dexcool (Orange) no matter what!
26.32%
Green (Universal) no matter what!
47.37%
Leave whatever you have already, dangerous to switch
15.79%
Confused by the disagreement.
10.53%
Voters: 19. You may not vote on this poll
List of concerns/issues - 2001 Disco SE - comments? ideas? solutions? Thanks!
Old May 17, 2010 | 11:37 AM
hilltoppersx's Avatar
15a. I use the Lucas and I love it.
20. do you have an aftermarket stereo? or what plugs do you have on? if they are not insulated that can cause some interference.
Old May 17, 2010 | 12:18 PM
discoinchatty's Avatar
Originally Posted by collector87
-(NEW ITEM: 31.) Quickly change green coolant to orange dexcool - have t/stat replaced at this time (~$18 part + complicated labour - 1 hr.) - change will not compromise head gasket, etc., however, leaving the green would be bad
I always thought it was better to get rid of the dexcool since it can cause degradation of the head gaskets? I was running dexcool but switched to the green. Did I misread something somewhere?
Old May 17, 2010 | 12:25 PM
It is controversial. Some say that the dexcool (orange coolant) does cause deterioration of the gaskets and can even clog the radiator and other bits up, while others argue that is wrong. I am currently still using dexcool but plan on flushing it out and switching to a universal by peak.
Old May 17, 2010 | 01:27 PM
yloDiscoII's Avatar
It seems to be that the big problems people have with Dexcool are when it comes in contact with air when there is some sort of leak....like in the case of the throttle body heater plate.
Old May 18, 2010 | 11:04 AM
collector87's Avatar
I have new observations about item 20. Now 20a. and 20b. There are two different sounds which I was confusing!
20a. This "air" like sound seems to be an electronic sound related to having the sound system on - the original sound system is tuned to an unused radio frequency and an iPod is connected to an FM tuner powered through the front power jack. This sound will change as the transmission shifts and is gone when the sound system is off.
20b. This "air" like seems to be related to accelerating in drive. This sound is loud when not depressing the gas pedal and will get quieter and eventually go away as you depress the gas pedal further. I also noticed today that if you do this in neutral (press the gas pedal) the sound stays the same, but, if you do it in drive the sound will diminish as I just described.
Old May 18, 2010 | 11:26 AM
your poll is incorrect. green coolant is not universal coolant.
There are loads of different coolants. Japanese green, Toyota red, Korean or European blue, or European yellow and of course GM orange.
For your truck. Dexcool aka orange is what GM recommends for Alumium radiators.
Your truck will run fine on Universal which can be mixed with Dexcool or Green coolant.
Green coolant cannot be mixed with dexcool therefore its not universal.
Old May 18, 2010 | 02:08 PM
salve7's Avatar
This thread reads like "War and Peace"... I'm lost
Old May 18, 2010 | 03:54 PM
ROVERTECH15's Avatar
this is correct and i would switch to the peak universal which is yellow
Old May 18, 2010 | 05:48 PM
vandev's Avatar
Dont forget about the g48 or the blue coolant...
Old May 18, 2010 | 06:35 PM
i mentioned it . its another european and korean coolant.....
