a little help Identifying lines & hoses
while working on my truck last weekend I found a few lines and hoses that were disconnect before I did the heads gaskets and timing cover.
2.jpg is a hard plastic line running over the master toword the coil pak but has nothing connented to it?
1. jpg is a broken vacuum hose connected to a canister(???) on the inner fender below the cooling recovery tank?
3.jpg was a victim of my quarts work light, can I cut it a spice in a piece of vacuun line or head to the dealer?
downsize (3) is a plug that I found on the left fender well to the rear of the washer bottle.
Before the work last weekend the only thing I think was not working was the cruise. So i'm assuming one of the might effect that,
but I'm not sure i've only had the truck 6-weeks or so.
#2: you have some breather hoses back there, one for the tranny and one for the transfer case. The end with a candy cane bend.
#3: brake vacuum pipe, I guess cut it and patch it with some vacuum hose.
#1: can't figure this one, where does it go?
