Little Help Needed
Old Sep 4, 2009 | 11:45 PM
00&04 Disco's Avatar
Default Little Help Needed
I was taking off my intake manifold and the tube that is feeding cooland into the rear of the manifold broke. What is this called so I can order a new one. I can not find it on any of the websites or RAVE manuals.
Old Sep 4, 2009 | 11:51 PM
NiteTrain's Avatar
DI or DII? the throttle body has a coolant line going to it but I don't think the rear of the intake does. I'll look on mine later and see.
Old Sep 4, 2009 | 11:59 PM
2004 Discovery II
Old Sep 5, 2009 | 03:13 AM
lipadj46's Avatar
You buy them by what they are connected to. So for instance the hose from the expansion tank to the throttle body is:
http://www.roverparts.com/Parts/PCH000420G.cfm
and the hose from the plenum to the valve cover:
http://www.roverparts.com/Parts/ERR7411.cfm
Which one is it?
Old Sep 5, 2009 | 10:41 AM
Default Lipadj46
It looks like the hose from the plenum to the valve cover but it doesn't have the plasitc quick connect that I need that goes into the plenum. My hose isn't what I broke, I broke the plastic connector that comes out and than 90's to the passanger side, but not the valve cover. I have the valve covers off and the heads off and it is still connected somewhere behind the block or somewhere else, I will look and see and get back to you where it originates but it isn't the valve cover.
Old Sep 5, 2009 | 01:29 PM
oysterhead's Avatar
Take a picture
Old Sep 5, 2009 | 02:41 PM
lipadj46's Avatar
Yes take a pic not sure what you are talking about.
Old Sep 5, 2009 | 10:31 PM
I feel like a dumb A$$ but it is not actually the intake manifold but the fuel feed rail that I still have attached to the manifold. The two lines come down to the back where they connect to make one and the plastic piece that connects the fuel rails to the fuel feeder line is what I broke and can not find a replacement part. Sorry for the confusion, I guess I just had to go back to the shop and look at what I was talking about.
Old Sep 5, 2009 | 10:50 PM
lipadj46's Avatar
So are you talking about the hose that connects up to the line labelled 6 in the pic below?
Old Sep 6, 2009 | 11:58 AM
Yes and NO, the part I need is the connector that slides over the steel inlet valve for the fuel feeder rails and than 90's to the passanger side and connects to the rubber fuel feeder line that is shown as part 6 on that diagram.
saltyrover
Apr 25, 2013 06:44 PM
skezixx
Sep 26, 2012 08:28 AM
schultze5100
Mar 24, 2008 12:32 PM
LPs HSE
Jun 19, 2007 09:12 PM
love2disco
May 10, 2007 10:38 AM
