locating fuel filter
Old Oct 25, 2005 | 10:29 PM
nottin's Avatar
3rd Gear
Default locating fuel filter
hi everyone,need help on replacing my fuel filter,could anyone tell me where it is located and what spark plugs I should use,I would like to give my 2001 disco sd a tune up.
Old Oct 26, 2005 | 12:47 AM
05LandRover's Avatar
Default RE: locating fuel filter
disco? i dunno, maybe check in the owner's manual, if you don't have one
call 18004335602 and ask for Land Rover Service and ask them
that is Autobahn Land Rover in Fort Worth
Old Oct 26, 2005 | 02:37 AM
wildhorses's Avatar
It is under the right rear wheel well along the frame. Inline filter with two nuts that loosen the line and a bolt that secures the filter to vehicle. The hard part is getting the metal band that holds on the filter to the veh ( via a nut you loosen) loose enough to pull out the old filter. Loosen nut as much as you can then twist the filter working it free. Not a bad project filter available at napa if you are in the states.
Old Oct 26, 2005 | 07:11 AM
nottin's Avatar
3rd Gear
I have a 2001 disco,is the fuel filter under the right rear wheel for this year also,thanks for your help.I got the in line filter from autozone for $5.99,great price ,I'll check later to see if I can find it
Old Oct 26, 2005 | 09:02 AM
MEP's Avatar
MEP
Remove the wheel-it easier this way(trust me,Iknow)
Old Oct 26, 2005 | 07:30 PM
mikemeyer0's Avatar
yea, taking the pass. rear wheel off helps out a lot. Filter is avail at the normal places (autozone, napa, checker). As for spark plugs the parts store can look up the ones you need, stay away from the 4 tiped ones, people have problems with these in the disco, (although some don't), Just buy a good set or call AB and order them, can't really go wrong there.
Old Oct 29, 2005 | 05:32 AM
wildhorses's Avatar
Yep, removing the wheel would save time as it is a mild pain in the **** doing it with the wheel on due to clearance to wrench. I did it the hard way this time, but will take wheel off when I cahnge it next time. Running decent fuel, how many miles should I change it at? 10k? 20k?
Old Oct 30, 2005 | 12:40 AM
Bait's Avatar
Disco II's do not have a fuel filter.
Old Oct 30, 2005 | 12:57 AM
nottin's Avatar
3rd Gear
Thankyou Bait,looked everywhere that is why I posted in the first place,
Old Oct 30, 2005 | 12:58 AM
MEP's Avatar
MEP
ORIGINAL: Bait
