Locking Lug Nuts?
One caveat you should consider. Even though I routinely told tire shops to not use the air wrench for zipping lug nuts on and off they sometimes did and the last time ruined one of my locking nuts as the key shaped metal insert inside the locking lug nut socket twisted out of it's mount. They couldn't figure out a way to remove the nut and I was pissed and took my car home and the only way I could get that locking nut off was to pound an old over-sized 6 pt socket onto the rounded shape of the locking nut until it was jammed on and then remove the nut. So if you get these I suggest you remove them yourself before getting tires worked on and put them back on afterwards.
Just pulled the trigger on these:
http://www.ebay.com/itm/LOCKING-WHEE...item334d4b8af1
New set of 5...shipping was about $25 from UK, so that's not the best, but it's still $50 cheaper than the cheapest USED OEM set. Doesn't come with cotton gloves though.
bcolins
05-13-2011 01:31 AM
