Long-time owner, first time door-trim-remover
Well, ok, I've had it two months. ;-)
But I've never pulled a door panel before, and Robover's nice write up from this morning notwithstanding, I'm still a little nervous about it.
I'm going to tentatively assume that my vapor barriers are gone, unless the mechanic at the Little Lot is very impressive... but I need to pull the RF and LR panels to look at the lock actuators, neither of which seem to be working. RF was, LR wasn't, when I bought it.
I'm speculating the RF plug just came loose.
I've read the RAVE, but I'd like to see pictures of the 10 spring clips, so I know what I'm up against; anyone got a door open right now that they can take pictures of?
Do you really *need* that fork-tool to pop the clips without trashing the door panel?
Say yes to the tool, you will thank us later. Besides it works on just about every vehicle out there. Just a note on the clips or "fastners", they are available from most of the usual rover parts outlets, and I tried to find some at the local auto parts stores with NO luck so the less of them you break the better. AND......the side doors take different ones than the rear door panel. If you broke one or two you could put things back together with out much problem anyway.
and I believe that the Bulgarians have the flight contract, unless they have been recently outbid by the Nigerians (lol)
