Looked in Rave, but not seeing the coolant drain points
EDIT: I pulled the hose as recommended by several. Thanks all.
I've looked in the rave and been under my 2001 disco a few times now.....not seeing the coolant drain points (look like washer head bolts in the rave) they show on the block.
Can someone steer me to the drain points or should I just pull the lower radiator hose (which will make a mess in the driveway as its above a frame rail)
BC
BC
BC
I'm wondering if this contributes to temperature problems and head gasket issues. I'm just thinking.. um.. out loud?
I had a 1989 Acura Legend that had drains on the block. Everyone I talked to said not to worry about them, just use the drain on the radiator and you'll be fine. Well, I'm kind of difficult sometimes, and the drains weren't too hard to get to. I opened the drains.. and... nothing. I removed the drain plugs completely. Nothing. I took a pocket screw driver and stuck it up in the drain hole and punched through some scale or something, and the coolant started running out... presumably with some of the buildup.
I'm inclined to try the same thing on my rover if I can get to the plugs without pulling the engine.![Smile](https://landroverforums.com/forum/images/smilies/H5uKDcM.png)
Any thought or experience pulling these plugs? Does any extra trash come out too?
You will need to get creative with your socket set. The plugs are square drive, so a smaller 6 point socket might work. They are way the heck up there. If you have a lift on your Rover they are easier to access. They are also at the angle of the cylinders, so you may need a wobble extention additionally. Mine were super tight. I ended up leaving them alone. If you get them loose I would put them back with red loc-Tite.
The plug on the left can be reached, use a flat 10 or 11mm open wrench IIRC. The one on the right is a bitch, it is tucked up behind the engine mount and the exhaust manifold somewhere, almost impossible to get to.
I just let those plugs be and popped off all the hoses and flushed the block with a garden hose, then rinsed out with distilled water You can get most of the block drained just by removing the hoses.
