I found two types of Abs Modulator switch's need help?
Old May 9, 2011 | 07:11 PM
X53Gunner's Avatar
Default I found two types of Abs Modulator switch's need help?
I was doing the modulator fix and my switches do not test out while testing I just get straight 0's on my multimeter. I was looking at getting the new switches and not sure what the huge difference is between the two maybe Mike or someone can enlighten me... Thanks a bunch!!! Also if i have bad switches is 0 what normally shows on the multimeter ? Thanks all!
Scott
ABS Modulator Shuttle Valve Repair Kit | Brake Parts for Land Rover & Range Rover
ABS shuttle valve code solution; brake fluid leaks
Old May 9, 2011 | 08:19 PM
Bundu's Avatar
Banned
The shuttle valves are the same thing, the falconworks kit has 2 little o rings and 4 clips included. You can buy the shuttle valve from AB and the seal kit from falconworks and save about $60. I bought both (like and idiot) because someone said the falconworks shuttle valve is newer improved etc, it's the same part in the same box from Wabco.
kman3786
Mar 12, 2014 09:51 PM
stormatzio
Apr 30, 2013 09:00 AM
bosshogt
Dec 23, 2011 10:24 AM
audioclay
Nov 16, 2009 09:47 PM
OxyCoRover
Feb 19, 2008 02:32 PM
