looking at a 2000 Discovery
Old Feb 21, 2016 | 06:37 PM
  #41
BS50MGSXR's Avatar
so lucky 8 front axle for $198 sounds great.
is it better to go with AB for the coolant hoses over the none OEM stuff at Lucky 8? lucky has top hose, thermostat pump hose, bottom hose, lower expansion tank hose, and low temp thermostat for $230. or just get that regular thermostat?
just was thinking id order all with one place was all.
Old Feb 21, 2016 | 10:14 PM
  #42
Dave03S's Avatar
Get the low temp thermostat for sure. Lucky 8 carries the real LR one that you need and won't steer you wrong.
Aftermarket ones are not the same.
Saving a few bucks on an off brand stat is an indication that you should not own a Land Rover.
Sometimes you just have to do the research and pay up to get the best possible result... No sense in doing otherwise. Especially if that difference is less than $50.00
seymourducketts
Jun 25, 2010 06:01 PM
parlain44
Dec 19, 2008 02:11 PM
jonfit04
Jun 3, 2008 06:22 PM
xavierf11
Dec 22, 2007 05:54 PM
Airwolf1
Nov 6, 2006 04:27 PM
