Looking for a bit bigger than 255/65/16
Old Dec 20, 2013 | 08:56 AM
me 2's Avatar
Default Looking for a bit bigger than 255/65/16
I have a set of 255/65/16 a/t on the disco and I put a 2" lift on it after so I wned to go with more of a bigger tire but not much taller, more wide. Any suggestions? Im going to go with a m/t this time. Thanks
Old Dec 20, 2013 | 11:07 AM
jeffh's Avatar
265/75/16 is what I run but I wish I had gone 255 instead.
Old Dec 20, 2013 | 11:13 AM
jafir's Avatar
Wider tires have their place, but narrower tires are best in more situations. And they are easier to fit usually.
Old Dec 20, 2013 | 11:16 AM
dusty1's Avatar
i've been using this Tire Sizes to get a more accurate o.a. dia. to specific tires in their metric conversions. because 285/75 is not always an exact 75% of 285, depending on the manufacturer
Old Dec 20, 2013 | 04:12 PM
DonRW2007's Avatar
Default I run 265/75R16...
...on a 2" lift. I think they look really good, and haven't had any problems with rubbing, etc. to date. I can pits a picture if you'd like...
Old Dec 20, 2013 | 05:10 PM
scottmb23's Avatar
265/75/16 Kenda Klever Mud Tires with spacers (to clear control arms at full lock) and 2" MD Terrafirma lift. Had to trim rear wheel arches and front bumper for clearance/approach.
Looking for a bit bigger than 255/65/16-image-4255418060.jpg
Old Dec 20, 2013 | 05:55 PM
ScreamingLife's Avatar
265/75R16 is your tire of choice. I personally prefer BFG A/T KO. I've had nothing but a good experience with them. With a 2 inch lift you could probably stick some 255/85R16 under there as well.
Old Dec 20, 2013 | 06:22 PM
Big Jim Swade's Avatar
255/70-16's will be about an inch taller than the 255/65-16's stock size. About 30"
Old Jan 6, 2014 | 10:32 AM
SuperSport's Avatar
I just installed 265/75R16 and NO rubbing at all. They Look GREAT and fill in the wheel well nicely.
Old Jan 6, 2014 | 10:34 AM
ZGPhoto's Avatar
235/85 would be the best
but if you want wider(not better) 265/75 as others have noted.
