looking for brake fluid reservoir rubber grommets
Old Oct 17, 2011 | 11:27 PM
elrocha69's Avatar
Default looking for brake fluid reservoir rubber grommets
I am having trouble finding these and mine are leaking. Do I have to buy a whole new reservoir to get these or will I end up having to go to the dealer?
Old Oct 18, 2011 | 02:12 AM
buick215's Avatar
I have never seen them for sale separately. You have to buy the whole kit Brake Master Cylinder Reservoir Kit. | Brake Parts for Land Rover & Range Rover You might be able to find similar rubber seals at Napa or Ace Hardware but they will probably give you problems.
Old Oct 18, 2011 | 04:15 AM
Would suspect that once you replaced them, other rubber parts in same unit may begin to show their age as well. May be best fix to replace, shop around for prices.
The American Indian translation for "vegetarian" is "bad hunter"
Old Oct 18, 2011 | 08:25 AM
You can buy the entire master cylinder kit, that includes the bushings from Atlantic British.
Old Dec 8, 2011 | 09:35 AM
Mr. Clean's Avatar
If all your doing is the res, would you have to bleed the system afterwords??
parkerlander
Nov 11, 2020 02:29 AM
parkerlander
Nov 5, 2014 12:41 PM
Trickymonk
Feb 10, 2012 09:12 AM
