Looking at a Disco Today
Old Apr 22, 2020 | 12:10 PM
TheBestCow's Avatar
Default Looking at a Disco Today
1. 91k miles
2. Has Dexcool in it
3. Idling at 217-220°
4. On interstate temp drops to 197-199°
5. Coming off interstate starts heating up to 204-207-212
6. Fenders need to be refinished per normal
Water pump and radiator replaced at 40k.
Thoughts? Has a 195° thermostat in it.
Old Apr 22, 2020 | 12:12 PM
Dave03S's Avatar
Sounds like it is still stock, yes. I'd find out what oil they are running in it... Hopefully not 5w30.
Old Apr 22, 2020 | 12:14 PM
TheBestCow's Avatar
Also has a rattle in the left vent, when going max A/C it kind of rumbles (like I can hear the a/c fan spooling up pretty aggressively), and right after the interstate drive the 3 amigos kicked back on after supposedly being fixed. Right turn signal, the first time I used it, it took a second to begin clicking on the dash which was odd, did it one other time but the rest of the time it was fine.
Trying to check my gut here.
also has had the valve cover gaskets done. No leaks.
Old Apr 22, 2020 | 12:25 PM
TheBestCow's Avatar
So any major concerns or just swap in a 180°, flush the Dexcool, and should be fine? How loud should the AC/Heat be when turning it on?
Old Apr 22, 2020 | 12:53 PM
redwhitekat's Avatar
The 3 amigos and probably a few other things you can use to negotiate price
how much are they asking
and how is the rust and body
Old Apr 22, 2020 | 12:58 PM
Best4x4's Avatar
3 Amigo's being intermittent = usually a ground fault, shuttle valve switch, or the wiring. Very simple fix with Option B repair. I would install a 180F thermostat, and switch to green coolant. If you are new to LR's I highly recommend getting it inspected by an independent LR shop.
Old Apr 22, 2020 | 01:00 PM
TheBestCow's Avatar
no rust.
body not as clean as described.
over $10k
I think I’m going to walk.
Old Apr 22, 2020 | 01:04 PM
jastutte's Avatar
Originally Posted by TheBestCow
no rust.
over $10k
over $10,000?!?
definitely walk away.
Old Apr 22, 2020 | 01:15 PM
TheBestCow's Avatar
Originally Posted by jastutte
over $10,000?!?
done. Thanks. Hunt continues.
Old Apr 22, 2020 | 01:38 PM
Dave03S's Avatar
"How loud should the AC/Heat be when turning it on?"
If it is loud enough that you noticed it being odd, probably too loud, which is most likely debris in the blower fan cage. One thing that will lead to this is running a long period of time without a plenum filter in place... Not a deal breaker but always good to see if the plenum filter is there, just below the cowl under the hood. Long strip of grey foam going across the whole vehicle. If they don't bother replacing that it can tell you something about the maintenance. I see a lot of pics on here of folks running without them, it isn't unusual, but it does allow all manner of debris into the fan basket.
Amazon Amazon
