looking to get my first disco
ok im looking at to get my first disco, ive found 2 that im interested in but i dont realy kno the deference between the two. And does the 02 have the cdl? The 2 that im am looking at is the 01 and the 02 witch one is beter?or are they just exactly the same? lol
thanx
Platinum Auto Exchange - www.platinumautoexchangeinc.com
thanx
the 01 if it has the CDL tit in the transfer case. ACE was not that common as it was a $1600-$2000 option depending on the year. Both trucks have relitively low mileage 85k, but that is were they are going to start costing money. 85k and up is were you can start looking at rebuilding drive shafts, water pumps, head gaskets, high mileage maintenance (check the post its) just make sure you keep enough money aside for repairs. Otherwise welcome
As been mentioned, you are likely looking to spend some dollars as soon as you get either of the Discos. The front driveshaft is a mandatory repair the minute you get it home. Head gaskets will be needed soon, if they aren't already leaking. I would have an extensive pre purchase inspection done on any truck that you are looking to buy, money well spent. if you want a new hobby and a truck that is great off-road, and looks great, get a disco, if you want daily transportation and four-wheel drice, but don't want a truck that will require work and money, you might consider a 4runner........good luck. The nice thing is that if you have a spare vehicle and several grand in your pocket, after you buy the truck, you will get to learn a ton about how to diagnose and repair a disco, The Rave manual is essential, you can download it for free from this site. You will also end up checking Land Rover Forums on a daily basis and Disco Mike will be on your speed dial! Good Luck. Phil
thanx for all the info. so would i be better off to look at one with a little over a 100,000 miles or would i just be in the same boat? and i look forward to working on my new truck im pretty mechanically inclined so thats not a worry.would this disco be worth looking at? im kind of weary of the price for this one? thanx again
2004 Land Rover Discovery SE, $7,495 - Cars.com
