Looking for headliner net/trays
Old Sep 27, 2020 | 11:55 AM
ReconDoc83's Avatar
Default Looking for headliner net/trays
The plastic “U” shaped brackets with the netting on the headliner; one of mine is broken off. I imagine I need to replace both to ensure they remain the same color.
mine are tan...
anyone have a set?
thanks
doc
Old Sep 27, 2020 | 06:24 PM
Extinct's Avatar
Check facebook sellers, I am sure there are several.
Old Sep 27, 2020 | 08:20 PM
mln01's Avatar
Or check with Paul, Abran or Will.
Old Sep 28, 2020 | 07:56 AM
RoverPA's Avatar
Member
There's a tan Disco at my U-pull it yard. I can go check if you want me to.
Old Sep 28, 2020 | 09:51 AM
ReconDoc83's Avatar
if you wouldn’t mind and can get a good deal!
be a bitch to get them out, without pulling the liner or stripping the nuts.
thanks
Old Sep 28, 2020 | 12:24 PM
redrover75's Avatar
I just used some sheet metal screws from behind. Turns the plastic screw into a net. works great and probably better than looking for an old piece of plastic that will probably break anyway.
Old Sep 28, 2020 | 03:25 PM
logan_gibson's Avatar
I've got a set.
Yes you need to drop the headliner to access the backside to replace them.
Feel free to shoot me a PM, I don't have notifications turned on for the forum.
Old Sep 29, 2020 | 02:47 PM
RoverPA's Avatar
Member
thanks
OK. I'll go check tomorrow. Let me know if you still need them by them,
Old Sep 30, 2020 | 09:16 AM
nashvegas's Avatar
Heads up they are all the same color. "LUM" is the color code at the end of the part #'s.
My 00 was missing them from headliner redo when I bought it so I sourced from junkers too.
So even though they look a bit different depending on interior color reflections, all the same.
Only diff is that in 03/04, they added little warning label tags on the side of the netting. You can keep those or remove them.
Sean Winter
Aug 18, 2020 09:00 PM
BrandonG83
Apr 30, 2015 02:47 PM
jalodge
Sep 22, 2013 12:12 PM
Ross Landiepanzer
Jan 7, 2013 04:55 PM
Aj6543
Sep 19, 2009 03:44 PM
