Looking to install Gauges
Old Jan 30, 2017 | 11:12 AM
RawFaith's Avatar
Default Looking to install Gauges
Looking to install gauges on the disco:
Water temp
Oil Pressure
To start, and maybe trans temp?
Anyways, quick question:
What fuse to "tap into" for the dim light on for the gauges?
Thanks in advance
Old Jan 30, 2017 | 01:59 PM
OffroadFrance's Avatar
Water temp
Oil Pressure
Thanks in advance
I can't answer your question but that is a very good choice of additional gauges, they are exactly the same gauges I chose.
Old Jan 30, 2017 | 02:15 PM
Luckyjayb's Avatar
maybe jeff Blake will chime in. I think he just did some. Heck you think there would be a way to use the dimmer for the instrument cluster or even tap into the dimmer wire for the radio harness
Old Jan 30, 2017 | 03:04 PM
RawFaith's Avatar
Thanks for the reply, will like to see your set up.
It sucks that nobody makes a triple gauge pillar pod for land rovers!
I'm pretty sure there is a way and that someone had found it.
I doubt it We will be the first doing this mod.....but you never know
Old Jan 30, 2017 | 03:15 PM
Red5's Avatar
I tapped into the circuit for the parking lights. Fuse 33, it is a red/orange stripe wire coming out of the fuse panel.
Old Jan 30, 2017 | 03:22 PM
KingKoopa's Avatar
Why not just go with an ultragauge?
Old Jan 30, 2017 | 03:24 PM
KingKoopa's Avatar
Nevermind, forgot there aren't any pids for trans temp and oil pressure
Old Jan 30, 2017 | 04:02 PM
Jeff Blake's Avatar
Auber gauges
I think I tapped into the headlights for the dimmer
Glowshift oil filter sandwich adapter for the oil pressure and temp
Glowshift water temp sender for the coolant temp
Old Jan 30, 2017 | 04:10 PM
KingKoopa's Avatar
That's pretty cool, super clean. What's the fourth gauge for?
Old Jan 30, 2017 | 04:12 PM
Jeff Blake's Avatar
haven't hooked up the amber one yet. Probably voltage, or transmission temp if I can find a good way to tap in
