Looking to Purchase a Disco II
Old Feb 8, 2022 | 09:57 AM
Richard Gallant's Avatar
Fuel think hard about fuel they are not economical in any sense of the word. You get 200 - 300 miles to a 25 gallon tank. And ideally need to run 89/91 octane fuel.
Old Feb 8, 2022 | 07:34 PM
Frank4's Avatar
I recently started using an app to track mileage instead of pen and paper. I was hoping the app would show a little better MPG than I was calculating. Turns out I was on the money. A whopping 8.2mpg!!
Old Feb 8, 2022 | 10:02 PM
Extinct's Avatar
Frank4:
2000 DII 150k
Equipped:
RTE 3" coils
Terra Firma+ 2 shocks
BFG AT's 33"
ARB front bumper
AB rear bumper
SD rack
Hella 4000 on ARB
Hella 3000 on SD rack
Resonator Delete--> Do This!
Magnaflow 12586
Bypass your throttle body warmer!!!
Lift, 33's, rack, lights on the rack, You were never intending to get mpg with that rig. Keep it stock height, Michelin street treads, no rack. I get 17 consistent going 75 mph. Ain't the Disco's fault, if you want mpg with all that gear you need a diesel, but then Diesel if $4/gal
Old Feb 9, 2022 | 01:17 AM
The Deputy's Avatar
Yeah, as mentioned...is this going to be your primary or just a secondary driver? One will be difficult, while the other tolerable...especially considering your lack of mechanical skills.
But, truth be told...driving any 18+ year old vehicle as a daily will be challenging.
With that being said...if you do decide to follow this endeavors winding road. Do an extremely long test drive, maybe a couple, getting vehicle to operating temps, especially watching for coolant issues, check previous maintenance records, don't trust anyone that says..."it's a rover, so it's suppose to leak fluids"...because they shouldn't if properly maintained, check to be sure all warning lights appear when you turn on the key, CHECK FOR RUSTED FRAME!!! and if you are unfamiliar with looking at rovers...take someone with you that is.
Good luck.
Both our 03 and 04 average 14.5...with just slightly larger/aggressive tires.
The family...
They can be addicting.
Old Feb 9, 2022 | 07:07 PM
longtallsally's Avatar
So the economy part of this is really funny. I was a little bored at work today so I did some mild calculations. If I drive the S4 (which takes premium) and even taking into account the significantly higher cost of fuel for it, driving a Disco would still cost over $100 more a month in fuel for my commute. I personally don’t believe in running premium in a 50+ year old design engine, so that’s assuming tractor gas, which is what I ran in my last one. The funny part is the Jeep splits the difference as it gets better economy than a Disco.
Old Feb 9, 2022 | 11:58 PM
Frank4's Avatar
Originally Posted by Extinct
Frank4:
2000 DII 150k
Equipped:
RTE 3" coils
BFG AT's 33"
ARB front bumper
AB rear bumper
SD rack
Hella 4000 on ARB
Magnaflow 12586
Oh wow! Thanks for pointing that out. I thought I had a hole in my gas tank.
YOU ARE A GENIUS.
Old Feb 10, 2022 | 06:30 AM
Extinct's Avatar
Yeah, its hilarious when someone with a fully kitted 4x4 starts talking about fuel economy. Like somebody with a Big Block Chevelle or an off-shore power boat talking about fuel economy. Some of us don't care. I recently switched to a permanent WFH job, I bet I drive less that 20 miles a week at this point. I look at fuel prices and think in my head "ouch", but doesn't affect my life much at this point aside from the obvious inflation we all see.
Let's go brandon!
Old Feb 10, 2022 | 11:45 AM
Yea mine has become a daily driver same thing a short distance 30 mile round trip, but with gas at about 7.00 a gal for 89 it is a bit painful.
Old Feb 10, 2022 | 01:18 PM
Harvlr's Avatar
I put on less than 10,000km a year on the D2 and P38 combined so the cost of 91 octane isn’t really a big deal to me. Others that put on a lot more miles will find the price of fuel to be a bigger deal.
Old Feb 10, 2022 | 01:49 PM
redrover75's Avatar
Where are you located?
I think the take away on this you should not be afraid to get your hands dirty. The truck will not always break down in the most convenient place. Parts are cheap, they are easy to work on, you will probably have some initial growing pains, but get through the big stuff and it should be smooth sailing if you dont ignore maintanence.
