Looking for Recommendation for Water Pump Brand?
Old 10-27-2017, 07:08 PM
austinlandroverbill's Avatar
Default Looking for Recommendation for Water Pump Brand?
Here's the situation.
Rebuilt D2 HSE 4.6about 2.5 years ago.
Since then my son has put about 16-18K miles on it.
Started to overheat on him a couple weeks ago while at college.
Was losing coolant, visual inspection indicates the coolant is coming from the underside of the water pump -- assuming that like many/all water pumps, it has a weep hole for when bearing is beginning to fail.
Rebuild included a new water pump (won't mention vendor: last time I did that I ignited one heck of a sh#t storm).
Anyone have a recommendation of a particular brand: genuine, gates, britpart, etc.?
Would like to install a pump this time that will last more than 20,000 miles
Old 10-27-2017, 07:20 PM
Received 1,509 Likes on 1,236 Posts
I have always had good luck with Airtex pumps
https://frugalmechanic.com/auto-part...369-water-pump
Old 10-27-2017, 07:26 PM
OverRover's Avatar
+1, Airtex is the only water pump I use. Been using them for years and I've never had an issue with one yet. One brand to avoid at all costs is GMB. If someone gives you one...decline!
Old 10-27-2017, 07:31 PM
mln01's Avatar
Airtex sells two versions for the Land Rover. Choose the more expensive one or the less expensive one depending on how long you plan to keep the truck.
Old 10-27-2017, 07:34 PM
Good point forgot the better impeller here's a link to that one as well
https://frugalmechanic.com/auto-part...251-water-pump
Old 10-27-2017, 07:41 PM
Best4x4's Avatar
Received 2,272 Likes on 1,676 Posts
x3 Airtex
Old 10-28-2017, 12:09 AM
emncfi's Avatar
I got the cheaper airtex and have had great luck with it (185 at 70 in 100 degree weather, little higher with AC on)
Old 10-28-2017, 06:42 AM
I think the one we installed with the rebuild was in fact a GMB. Ugh.
Thanks for all the positive Airtex recommendations. I am going with that.
I actually thought that those were cheap reconditioned ones, but shows you what I know.
Old 10-28-2017, 06:58 AM
Ordered an Airtex.
Final question: should I just put the gasket on "dry" or should I goop it up with some RTV?
RAVE seems to imply a dry gasket.
Old 10-28-2017, 07:16 AM
I like hi tack for this job but find opinions on this topic vary greatly.
https://www.permatex.com/products/ga...asket-sealant/
Quick Reply: Looking for Recommendation for Water Pump Brand?
