Looking for someone to pin a slipped liner
Old Jun 3, 2016 | 08:27 AM
JimmyChooToo's Avatar
Default Looking for someone to pin a slipped liner
2003 Disco II. The noise is just embarrassing. Does anyone know a place or someone that can do it ?? Truck has only 85,000 miles, so I think it has a lot of life left once the liner is pinned. I am on the East Coast. Thank you.
Old Jun 3, 2016 | 10:10 AM
drowssap's Avatar
Check some of the older posts, there is someone which a shop in NJ ??? Rover master mechanic? I think is his username.
Old Jun 3, 2016 | 02:12 PM
Alex_M's Avatar
Yep, RoverMasterMechanic. He will weld the sleeves, I believe he is the one who came up with the welding idea. Haven't seen him around in a while, but you might still be able to contact him.
Old Jun 3, 2016 | 03:45 PM
cappedup's Avatar
I thought it was RoverMasterTech.
Old Jun 4, 2016 | 07:28 PM
vette427sbc's Avatar
Chris (RoverMasterTech) closed up his shop... I havent been able to get in contact with him for almost a year. A shame because he was good! Had him do head gaskets on 3 of my trucks.
What temperature do the liners slip? Sometimes a lower temperature thermostat can solve the slip.
Old Jun 4, 2016 | 07:35 PM
Alex_M's Avatar
Ah! You're correct, master tech. That is sad! I was wondering why he wasn't around. He always seemed to have some good insight.
Old Jun 5, 2016 | 05:53 AM
The first tap is at around 150F. It's not too bad, it's like direct injection tap noise. The rest of the orchestra comes on at around 200F, so a 180 degree thermostat should help things a little. Also, it's not too bad when ambient temperature is cool outside. So, in may become my morning coffee and bagel running car in the summer time.
I test drove a 2000 4.6 Range Rover P38 yesterday mainly to see what the engine should sound like. It's very nice. I really liked it and the car had really responsive brakes, which tells me my Disco II may need a new brake master cylinder too.
Thanks everyone for your help!! I really like my new to me truck. Super fun and nice pickup except for the noise.
Old Jun 5, 2016 | 01:40 PM
dr. mordo's Avatar
That's too bad about RoverMasterTech. He could be a bit of a blowhard, but definitely made some significant contributions to the community.
Good luck finding a mechanic who will pin or weld your sleeves. I hope you can find someone. You might find the threads here with pictures and print them out to show to mechanics you talk to.
Old Jun 8, 2016 | 08:54 AM
Okay, I love working on this truck. The parts are cheap and plentiful and so far it's easy to work on. I've been getting a check engine light since I bought it (P1412 / P1215), so swapped out the SAI solenoid (took this Noob only 15 mins even without instructions) and found a big crack (see pic). Hopefully this will clear it up for good.
Next, took it on a test drive afterwards and decided to crank the heat up in the summer, my slipped liner ping noise went down 40% in decibels. Now, I'm thinking water wetter and a new low temp thermostat can bring the noise down a bit further. Right now the noise is livable with the heat blasted. I know, LOL, but great truck. Love it.
Sarge103
Jan 9, 2016 03:04 PM
expedio2005
Mar 15, 2015 10:45 PM
utah95
Feb 14, 2014 08:47 AM
willrok13
Feb 8, 2013 11:31 PM
TurboLS1Driver
Jun 19, 2012 09:04 PM
