Looking for tips on transmission replacement.
Old Nov 12, 2018 | 12:13 PM
tcr6v1's Avatar
Default Looking for tips on transmission replacement.
I agreed to help a friend r&r a transmission after a front driveshaft mishap and looking for tips from people who have done it. Any tricks to make the job easier? How much of a pain in the $&$ is it
will also post pics to warn anyone who thinks they can ignore driveline vibration
thanks
Old Nov 12, 2018 | 03:16 PM
Sixpack577's Avatar
If you can't reach the top 4 transmission bell housing bolts from underneath, you'll have to support the engine, remove the motor mounts, and lower the engine.
That way you can reach those 4 bolts from the top,.
Old Nov 12, 2018 | 03:24 PM
Best4x4's Avatar
Lots of wobble extensions!
Old Nov 12, 2018 | 06:28 PM
The Deputy's Avatar
Removing the crossmembers and exhaust y-pipe normally requires a torch, to heat bolts/nuts. If you get the two trans mounts out, this allows you to angle the trans down in the rear and makes getting at the "10 and 2 o'clock" bell-housing bolts easier. The bell-housing bolts at "11 and 1 o'clock" weren't that bad, in my opinion, since you can see them and come straight at them from on top of trans, with several long extensions. I pulled the transfer case of the trans, before removing trans. So, l didn't have to mess with brake drum or electrical connections on transfer case.
​​​​​​​ Brian.
Old Nov 13, 2018 | 02:43 PM
T-rex's Avatar
I bought a transmission jack that really helped get the new transmission up and in.
https://www.harborfreight.com/800-lb...ack-69685.html
Greg Vasileff
Dec 23, 2017 05:57 PM
mcabrera3
Dec 30, 2015 04:08 PM
Russratt
Apr 28, 2015 09:20 AM
abran
Dec 5, 2013 12:08 PM
Bryan H
Jul 25, 2010 07:15 AM
