Sponsored by: CARiD
Transmission removal
Old Dec 25, 2015 | 11:07 AM
mcabrera3's Avatar
Default Transmission removal
Quick queston guys. How do you get to the top bolts on the transmission. (If any) I already removed the torque converter and all the visible bolts. Any help would be appriciated
Old Dec 28, 2015 | 10:07 PM
abran's Avatar
Separate t case from trans and undo trans mount to lower which make the top bolts easier to access, or
Remove engine mounts to lower trans and motor.
You can get to the top bolts with some long extensions, a few being wobble extensions or universal joints.
Old Dec 29, 2015 | 05:50 AM
drowssap's Avatar
what he said remove the motor mounts and lower the engine with a floor jack you will have plenty of room to get top bolts
Old Dec 30, 2015 | 04:08 PM
mcabrera3's Avatar
Thanks for the help guys I removed the transmission and swapped the fly wheel. After I installed the fly wheel and secured the torque converter I started to put everything back together. After I was done I turned over the wheel and it turned on beautifully. I moved it forward and it didn't move so I added transmission fluid. After adding transmission fluid it moved both forward and backwards. So I took it off for a test drive and as I was driving the check engine light started blinking and although it was in drive it wouldn't move. Today I tried it again and nothing. It shifts and the dashboard shows it switching but no luck. The only codes I get are p1884 and 1590. Any help would be great!!
jdwilks
Dec 24, 2015 07:57 AM
KinverTurtle
Dec 16, 2014 09:41 AM
hacksaw830
Mar 24, 2014 08:45 AM
Disco Den
Jun 23, 2010 12:13 AM
mikemeyer0
Oct 1, 2007 03:05 AM
