Looks like I bought a cursed '03... yay.
Welp, apparently, I didn't do quite enough research here first. I bought a DII inside the cursed vin range.
Now, looking over the engine and transmission from beneath before we bought it, it was clear that whoever owned it before me (bought it from a lot) really cared for it beyond the de-greasing and detailing that the lot would have done. I think it's somewhat safe to assume this might have been addressed already. I searched on the forums but didn't find anything on this so here is my question: How can I tell whether or not a previous owner already fixed this?
Details:
Discovery II SE7 vin 3A805...
113k miles
Details:
113k miles
Mine was not in the VIN range and I still ended up with a broken oil pump. So did some others with '04 Discovery. I lucked out because I was changing all the gaskets and seals and just happened to look at the oil pump and discovered that the outer ring was in 5 pieces.
Listen to the engine carefully and see if you can hear rattling in the front engine cover. Or even better.......do the oil pressure test. That will tell you everything.
I agree with the others. Not only do a oil pressure test, but install an aftermarket oil psi gauge! That is cheap insurance on an engine! I have a glowshif I mean glow **** because it is off by 20 psi!!!!!!!!!!! WTF? When the car is off, I should have 0 psi, so the gauge should be at 0 not below 0. So its off. I am going to call and complain tomorrow.
My oil temp one seems more exact. Glow shift has a nice sandwich adapter that I like, as far as gauges go, I would buy it from auto zone so if they are off you can take them back. I just set one on the right side, and one on the left side, of the steering wheel. Glow shift dose have pods for sale online. Some stack these gauges, some are triangle shaped. Ect...
