Looks like I've the broke coil spring.
Old Mar 30, 2009 | 07:16 PM
meltdowndave's Avatar
Default Looks like I've the broke coil spring.
The front driver's side coil has the two bottom turns completely mated together and now the rover tilts to the driver's side about 1" or so. Can't tell you how long it's been like that, only that I finally noticed the slight lean and had a mek-an-ick check it out today.
Since I added a winch and an aftermarket front bumper, I'm thinking about replacing the entire suspension and getting a slight lift.
I don't do any serious offroading, but would like to have the option to add slightly larger tires just in case. Does anyone have any recommendations in the $750 range?
Also...and perhaps mildly important, what are the long term problems of driving my Rover in case I can't get on it right away?
I'm not so keen on anything over 2", by the way.
Old Mar 30, 2009 | 07:27 PM
Call Tony at the LRRF, 650-365-4145 abd order a HD set of OME coils, springs and a steering stabilizer. 751 front coils, 762 rear and the HD shocks.
You can get it for a few bucks over you budget and will love them.
Old Mar 30, 2009 | 10:49 PM
AK Rover's Avatar
With the weight of a winch and bumper you definitely want to go with the HD suspension. The weight is probably the reason for your current spring situation. Just curios, why have a winch and bumper if you don't do serious off-roading?
Old Mar 31, 2009 | 07:19 PM
okdiscoguy's Avatar
Shopping carts can be heavy, and if you ever loose one in the grass, a winch will come in real handy.
Old Apr 1, 2009 | 07:23 AM
discoxd's Avatar
^^^^lol^^^
Old Apr 2, 2009 | 07:24 AM
kean's Avatar
wahaha
Snafu / Disco Fries
May 21, 2012 11:24 PM
2001SE7
Feb 13, 2011 01:11 PM
DiscoBenjamin
Dec 21, 2010 05:28 AM
grussell
May 24, 2009 09:00 PM
sloppyjoe
Apr 7, 2009 03:32 PM
