Losing Coolant
Old Nov 17, 2009 | 01:47 PM
Disco2Fever's Avatar
Thanks again, guys. I'm going to have my mechanic replace the head-gasket, and then we'll see if we keep having issues.
Mike, I'll let you know what he gives for an estimate. He's really good at researching online and figuring out how many hours the job is.
He only charged me $90 to replace my plugs and wires, and he did it by taking the intake off.
We shall see, THANKS again for all this help.
Old Nov 17, 2009 | 01:58 PM
Head gasket job on your engine is 11.5 hours plus any head work that might be needed.
Old Nov 18, 2009 | 10:18 PM
00&04 Disco's Avatar
I would say head gaskets for sure. Exact same cylinder her three months ago. Had to have the heads plained too. Make sure they are not warped or you will be doing the same job again soon. How old are the plugs and wires? Also while you are doing the gaskets you might as well change out the coolant from dexcool to normal "green" coolant. Atlantic British LLc has fair prices for all your parts you will need and well below dealer prices. Good luck!
Old Nov 19, 2009 | 08:07 AM
Roger that, thanks friend! I'm going to have the mechanic give it a serious once over, and I'll have the heads tested as well.
Do you think the green coolant is better than DexCool?
Old Nov 19, 2009 | 10:30 PM
Everything I have read on these forums shows that people have better luck with the green, some people even say that the Dexcool eats away the head gaskets but there is an underlying problem for this to happen. I have Dexcool in one and green in the other, guess I will find out. The only reason I still have Dexcool in my 2000 is that I have 105K on it and I am waiting for the HG to go out before I do the complete overhaul like I did on my newer one. Good luck on the job and keep us posted.
Old Nov 20, 2009 | 06:17 AM
Roger that, thanks!
Do any retail stores sell the green stuff? It is called "OAT Coolant"?
It's funny, I have a 2004 and 2000 as well. Does your wife drive the 2000, as in my case?
I think I might have a power steering pump going bad on the 2000 as well, but I'm not sure. One thing at a time
Old Nov 20, 2009 | 08:19 PM
http://sancarlosradiator.com/dex-cool.htm
Just about all you need to know about DexCool.
ScottinNJ
Feb 1, 2011 07:10 AM
tgwaldop
Nov 20, 2010 02:41 PM
alpineclimber
May 27, 2009 07:42 PM
kraelo
Apr 7, 2008 11:38 AM
jerome
May 21, 2007 04:26 PM
