Losing Coolant.
Old Sep 15, 2012 | 02:12 PM
Braxton's Avatar
Exclamation Losing Coolant.
I have 02 DII. We pulled into drive way this afternoon and it suddenly started to spray coolant. When I crawled under to see where it was leaking I saw steam coming from the lower right side front of the engine (facing the motor from the front), it appears to be coming from just above the oil pan near the bottom of the water pump/timing chain cover. I don't see any water lines in the area. Please any ideals? Thanks!
Old Sep 15, 2012 | 03:04 PM
Sounds like you may have blown a water pump, how mechanical are you?
Old Sep 15, 2012 | 03:08 PM
lr2001silver's Avatar
Banned
You need to wash off the area with a garden hose and then have the wife start it while you identify the exact location of leak sounds like a water pump, there is a hole on bottom side of water pump if that is where its coming from it needs to be replaced go for a water pump with the larger brass impeller for better coolant movement.
ScottinNJ
Feb 1, 2011 07:10 AM
Disco2Fever
Nov 20, 2009 08:19 PM
alpineclimber
May 27, 2009 07:42 PM
kraelo
Apr 7, 2008 11:38 AM
jerome
May 21, 2007 04:26 PM
