Loss of Power (No Codes)
Old Jul 3, 2014 | 12:29 PM
  #21
Motorhead1's Avatar
Did you have a cat related error code back before you replaced the o2 sensors?
Old Jul 3, 2014 | 04:22 PM
  #22
srockrae's Avatar
No Cat codes before. Went ahead and dropped off the truck and the Rover mechanic. I did the test drive with him. He thinks it is transmission related but he wants put it on the computer before diagnosing. Crap, new engine, new transfer case and now the transmission. I did not connect the power loss under load with a transmission issue. Man I hope its not worse case!
Old Jul 3, 2014 | 04:53 PM
  #23
Motorhead1's Avatar
Bummer....Hopefully it's just the e-brake!! lol
Old Jul 17, 2014 | 03:26 PM
  #24
srockrae's Avatar
PROBLEM SOLVED
Brought it to my Land Rover Mechanic who has the Land Rover Computer and he said it was showing misfires once it reached 2500 RPMS and said unless it continues misfiring that the computer will not store the code. Mine turned out being the plugs not the wires which were relatively new. I had put in Bosch Platinum Plus 4' plugs about 18 months ago and they were the culprit. My Land Rover Mechanic said they were the wrong plug and replaced them. I had selected them based on recommendations from this board. You live and learn. The main lesson learned here is that just because my ultraguage is not showing codes that does not necessarily mean there is not a misfire happening.
Old Jul 17, 2014 | 06:32 PM
  #25
Jared9220's Avatar
Originally Posted by srockrae
PROBLEM SOLVED
So are you going to tell us the name of these magical rover horsepower plugs or are they a secret?
Old Jul 18, 2014 | 06:31 AM
  #26
drowssap's Avatar
i have tried Bosch Platinum Plus 4' in just about everything, they seem to work great and **** the bed quickly. I never had that problem with regular Boshe platinum just the 4's.
The E-3 seem to run good.
Old Jul 21, 2014 | 02:11 PM
  #27
Jared9220's Avatar
Are you planning on telling us what spark plug your mechanic used to fix the problem or do you not even know?
Old Jul 21, 2014 | 02:31 PM
  #28
dusty1's Avatar
Let's bet!
$5 says the standard champs. any takers?
Old Jul 21, 2014 | 04:13 PM
  #29
Motorhead1's Avatar
Wow, thats surprising. Spark plugs. No power? You could never feel an engine miss during all this? Through me for a loop....Glad your all fixed up, and it was a cheap fix!!
Old Jul 21, 2014 | 04:36 PM
  #30
Jared9220's Avatar
Originally Posted by dusty1
Let's bet!
That's what I was thinking also. I hope we get confirmation. He was quick to trash the +4's but never gave the name of the others. I run +4's so i'd like to know if there's something wrong with them. What plugs do you run Dusty?
