Lost Key (no replacement)
Old Jun 30, 2014 | 08:57 AM
WNYErikDiscoII's Avatar
Former Sponsor
Originally Posted by Paul Grant
In the meanwhile, you can always disconnect the electrical portion of the ignition switch from the mechanical portion.
When you remove the steering column shround you'll see it's the portion of the switch on the left end of the assembly with all the wiring coming off it. Picture #1 is of the complete assembly as you will see it in your truck attached to the steering column.
There are two very small (eyeglass size) screws that hold the electrical section of the switch to the main body of the assembly. Picture #2 shows the end you will be removing and one of the small screws facing you. The other with be on the exact opposite side.
With the screws removed, the round black portion will detach. This is the final picture #3 (actually of the part from a Range Rover Classic as it's what I had at my desk). With that done, you can insert a screw driver into the detent you can see, turn and the truck will start just like it would with a key.
This is great info.
Along with this, we have brand new D1 replacement tumblers that you can retrofit with your existing D2 wires so you can have a key instead of a screwdriver. Its a great mod that saves $ by not going to the dealer.
Thanks Paul for the photos
Old Jun 30, 2014 | 09:10 AM
OffroadFrance's Avatar
Helping people to steal Rovers since 1993!!!
I always wondered how you guys 'aquired' new stock..........eerrrrr...........now I know...............
Old Jun 30, 2014 | 09:49 AM
Paul Grant's Avatar
Originally Posted by offroadfrance
i always wondered how you guys 'aquired' new stock..........eerrrrr...........now i know...............
shhhh!!!!
shayna798
LR2
Nov 2, 2009 03:37 AM
jmrmode
Jan 2, 2009 06:55 PM
ace00959
Jun 21, 2008 08:21 AM
pilsner
Apr 7, 2008 03:24 PM
Dahne23
Nov 4, 2007 05:50 PM
