Lost my owners manual quick question on oil change
I didnt shop around, I just stopped at a place on my way home from work that I know had them.
I am going to shop around between now and my next oil change, we were going on a 300+ mile trip pulling a 2,000 lbs. trailer the next day and I had to get the oil changed before we went so time was a factor.
Not to mention that all the little autoparts places around here that are not big box stores all close at 5pm on weekdays.
This is the filter that I bought.
It is a different part number than the ones you buy Anti.
zoom
Part Number: 51068
UPC Number: 765809510685
Principal Application: Agco Tractors, Chrysler (70-91), Ford/Mercury (83-97), Kubota Engines, Land Rover (95-04), Toyota (68-90)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.338
Outer Diameter Top: 3.660
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=10/26
Burst Pressure-PSI: 275
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 21
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.834 2.462 0.200
zoom
Part Number: 51068
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.338
Thread Size: 3/4-16
Gasket Diameters
Just some info on oil filters.
*your results may vary.
http://minimopar.knizefamily.net/oil....html#champion
http://www.bestcovery.com/node/12430
http://minimopar.knizefamily.net/oilfilters/index.html
http://www.calsci.com/motorcycleinfo...tml#OilFilters
I was bored so I thought I'd bore you guys too.
Some good info though.
