Loud clank when putting it into drive
Some gear backlash is normal and noticeable, even with U-Joints that are tight. And a DII will have gear lash in each of the three diffs.
That said, I wouldn't call the noise when putting my truck into gear a "loud clank".
I see that as of now you have 490 posts, so I presume your truck is not new to you. Has it gotten noisier lately?
Mine does that too if I park on a hill and let the truck rest on the parking poll. If I put the handbrake on first and then put it in park it doesn't do it. I think it's normal my parents Cars make the same noise if they're parked on a hill. Again only when shifting into reverse from park.
Ditto.. I also park on a hill, the sequence of parking brake and shifting into park make a difference in whether it clunks or not. I have trained myself to apply the P brake before shifting to park to avoid the clunk. Do the reverse when starting out... shift first remove parking brake second.
greenwade
05-05-2010 07:47 AM
