loud leaking power steering pump DII, 77k
Old Nov 23, 2009 | 09:17 AM
marcwestbmw's Avatar
Default loud leaking power steering pump DII, 77k
My power steering pump is making an awful lot of noise and is leaking.Friday night it was fine. Saturday morning after about 10 minutes, noise and fluid leaking. The fluid level never got below the minimum line. So, my question is will air in the system make a lot of noise? Would the pump go bad that quick? Do I start with line replacement then go from there?
Old Nov 23, 2009 | 09:24 AM
Urban Panzer's Avatar
The pump and steering box "should" self bleed after not so long, there is a bleed screw on top off the steering box if you need to get any trapped air out.
Where is it leaking from ? its quite common for the pump supply pipe to fail and leak.
Old Nov 23, 2009 | 09:29 AM
I took a look yesterday. But, really couldn't tell where the leak was coming from. I need to clean it up to see.
Old Nov 23, 2009 | 11:00 AM
troubled's Avatar
Mine was leaking from the gasket between the two halves, and was a howling monkey. Replacement took a couple of hours but not a bad job.
Old Nov 23, 2009 | 02:50 PM
Yes air in the system can cause the noise.
Old Nov 25, 2009 | 04:44 PM
IDAHO's Avatar
How do you get the air out?
Old Nov 25, 2009 | 08:26 PM
You can let it work its way out or you can loosen the bleed screw ontop of the steering box.
Old Nov 26, 2009 | 10:46 AM
Before you do anything, power scrub the pump, all 3 hoses and the gear box to find your leak.
Old Nov 26, 2009 | 03:03 PM
IDAHO's Avatar
Thats the first thing I did yesterday after I changed the fluid. It is leaking like crazy now. Coming from the hose that goes to the bottom of the power steering pump. At least it appears to be that hose. I haven't really climbed underneath to be sure. I don't know if there is a seal there or what.
Is there anything down there that could leak, or is this the hose. Is this just a matter of a bad seal between the hose and the pump, or is this a faulty hose?(lol, i mean typically....). Its funny because it makes noise still after starting it and even after I drive it around, but I stop and turn it off for five minutes, start it up and its gone.
Old Nov 26, 2009 | 09:27 PM
xengineguy's Avatar
I bet its the gasket between the front and back halfs of the pump.Does it seem to leak more when you first shut it off ? Is the resivoir tank full of little air bubbles? You can replace the print o seal "gasket" With gray "stiff" silicone if you cant find a new one.
