Loud whining in Low range at 20mph
Old May 16, 2025 | 03:19 PM
evil_goat's Avatar
Question Loud whining in Low range at 20mph
When driving in low range, I get a whining sound as the rpm approaches 2k. I usually don't hear it much at slower speeds, but when driving about 20mph, it sounded like this
The diff lock doesn't seem to change anything. I was told the noise is normal, but to me it sounds a little excessive. Is anything wrong?
Old May 16, 2025 | 03:34 PM
rikkd's Avatar
Oh boy that is not what we thought you meant at the time. Have you checked the fluid level/quality?
Old May 16, 2025 | 03:50 PM
evil_goat's Avatar
Fluid level is good. It was a darker brown color, but not black.
Old May 17, 2025 | 01:18 PM
rikkd's Avatar
When was the last time you changed it? Any shavings?
Old May 17, 2025 | 02:41 PM
disco96sd's Avatar
my transfer case made that whine - ended up replacing it and no more whine
Old May 17, 2025 | 03:24 PM
evil_goat's Avatar
I have never changed it, but I assume (hope) it was changed when the transmission was swapped about 10k miles ago.
Old May 17, 2025 | 03:26 PM
evil_goat's Avatar
Do you have any idea what was wrong with it? I would rather just replace a smaller component than the whole thing.
Old May 17, 2025 | 07:23 PM
Richard Gallant's Avatar
I would suggest draining and replacing the gear oil in the transfer case,you have no idea what is in there or what it is in. You should also check both diffs
Old May 21, 2025 | 03:11 AM
Dervish's Avatar
Why are You driving 20mph in low range?
Old May 21, 2025 | 09:35 AM
Harvlr's Avatar
I sometimes go more than 20 mph in low range. There’s a lake that I frequently go to where the “road” in has a lot of sections where you need to be at a crawl and a lot of sections where I can go over 20. I don’t think it’s necessary to keep changing between low and high range.
