Low coolant temperature
Old Oct 18, 2022 | 03:52 PM
Jamesh007's Avatar
Default Low coolant temperature
Coolant temperature is driving me crazy, reading between 145-155 on ultra gauge after replacing head gasket and full coolant drain, had replaced original thermostat with a factory 180, tried switching it back and it did go up about 5 degrees, bled it multiple times per procedure and tried a new 3rd thermostat, I’m convinced that the temperature is correct as I have put a thermal temp gauge on the block and radiator hoses and it is reading 150, I have checked belt routing and coolant hose routing and am at a loss. Does anyone have any ideas ?
Old Oct 18, 2022 | 05:20 PM
Harvlr's Avatar
If your temp reading is correct I’m pretty sure your new thermostat is faulty
Old Oct 18, 2022 | 07:30 PM
Extinct's Avatar
Why are messing with the POS factory thermostat? Use an inline and you can swap thermostat elements with no coolant loss. And yes, you have a faulty thermstat. I have three new factory style thermostats I am willing to give away if someone wants to pay the shipping cost for them, I will never used them.
cybercop
Jan 8, 2018 12:12 AM
johnbbensonjr
Apr 19, 2016 09:00 PM
north_nm_rover
Dec 6, 2014 09:35 PM
newtolandie
Jan 5, 2012 02:52 PM
TED
Oct 8, 2011 06:14 PM
