Weird possible overheating symptoms
Old Jan 2, 2018 | 08:10 PM
cybercop's Avatar
Default Weird possible overheating symptoms
Daughter drives the Disco II
says the following has happened twice
the temp gauge slowly creeps up to hot, light comes on. As she tries to safely pull over, the gauge drops back down to normal.
what could cause this?
seems to be creeping up to overheating and then cooling down with the engine running.
Old Jan 2, 2018 | 08:51 PM
mln01's Avatar
How is the coolant level in the coolant reservoir? And does what she reports happen a steady cruising speeds or only in stop and go driving?
Old Jan 2, 2018 | 08:57 PM
cybercop's Avatar
Steady speeds. On hwy coming home from college and then to work today.
She's off and doesn't go back to school until Monday. So I am going to drive it around tomorrow with computer connected.
I'll check the levels tomorrow. I just got the "Hey Dad, forgot to tell you earlier"
Old Jan 2, 2018 | 10:23 PM
alpinacsi's Avatar
Truck is cold, coolant low, temp sender is in air pocket, gauge starts reading hot in air pocket: boom! thermostat opens and coolant starts flowing by sender and gauge reads cool. Just a thought. Check coolant level and make sure the system is bled. Then find out why the coolant was low.
Old Jan 3, 2018 | 11:02 AM
cybercop's Avatar
Well, it was very low on coolant. Can't seem to see where it went. Filled up, attempted to bleed, don't see fluid leaking anywhere..
Hope its not a blow head gasket.
Old Jan 3, 2018 | 11:10 AM
abran's Avatar
Cheap pressure test kit from harbor freight works on D2s and LR3s.
Old Jan 3, 2018 | 01:10 PM
cybercop's Avatar
What range are the cylinders suppose to hold at?
Old Jan 3, 2018 | 11:32 PM
abran's Avatar
You will pressure test the cooling system at the expansion tank. 16 pounds and look for leaks/pressure to drop.
Old Jan 4, 2018 | 01:38 PM
cybercop's Avatar
Oh, I though you meant test the cylinders to see if there is a leak down. Do you just pinch the overfill?
Old Jan 5, 2018 | 06:07 AM
abran's Avatar
There is a cap adator in the kit that screws onto the overflow tank and has a fitting for the pump. Pump up to 16lbs and look for leaks.
