Low idle RPMs after trans fluid change
Old Jan 6, 2017 | 09:41 PM
treant985's Avatar
Default Low idle RPMs after trans fluid change
I changed the transmission fluid and included a bottle of Lucas during the refill. Transmission is smoother during changes, but at idle in drive, the RPMs will occasionally drop low, and on one occasion it cut off at a stop light.
I'm not sure what would be causing it. I did this same change (including the Lucas) about 5 years ago, and I had no issues afterwards.
Thoughts?
Old Jan 6, 2017 | 09:48 PM
Luckyjayb's Avatar
Idle air control valve or throttle position sensor. They were notorious on the fords 5.4litres.
Old Jan 6, 2017 | 09:59 PM
TjTalan's Avatar
My thoughts are that it's coincidental. I have however seen torque converter issues cause similar symptoms.
Old Jan 7, 2017 | 08:10 AM
treant985's Avatar
That would explain the low RPMs, but any idea why it would start after a trans fluid change?
Old Jan 7, 2017 | 08:16 AM
treant985's Avatar
I'm hoping it's coincidental, but it certainly wasn't doing it before the change, and it's definitely doing it after.
I wonder if it would help if I disconnected the battery to reset everything and let the ecu relearn proper idle?
Old Jan 7, 2017 | 08:26 AM
Luckyjayb's Avatar
Worth a shot
Old Jan 7, 2017 | 09:30 AM
NickAdams's Avatar
What trans fluid did you use? You mentioned the Lucas, but not the fluid. I always use Dex 6, which is thinner than the specified Dex 3, and add the Lucas, reasoning that the resulting thicker mixture is just about right. I've never had a problem.
Old Jan 7, 2017 | 09:51 AM
Luckyjayb's Avatar
I'd take the idle air control valve off and then spray the inside real good with carb cleaner and then dump the gunk out and keep doing that until the gunk it all gone then let it dry for a few and re install it
Old Jan 8, 2017 | 07:53 AM
treant985's Avatar
I used valvoline max life synthetic 'mercon lv': Valvoline 1 gal. high mileage Dex/Merc automatic transmission fluid VV322 - Read 2 Reviews on Valvoline #VV322
collin Barrows
Aug 28, 2011 07:13 AM
treant985
Dec 27, 2010 02:51 PM
Vertigo RT
Aug 20, 2010 06:04 PM
lucyyenic
Feb 5, 2010 06:06 AM
free_kid
13
Feb 3, 2010 12:56 PM
