lower windshield cowl finisher
Old May 28, 2015 | 09:22 PM
Celto 4's Avatar
Default lower windshield cowl finisher
looking to replace this the one in the Discovery Parts at Atlantic shows for Range Rover Rovers north has 259 complete with seals any suggestions besides dealer thanx
Old May 28, 2015 | 09:49 PM
Alex_M's Avatar
I just removed mine and made a cover for the ac intake so it wouldn't leak.
Old May 29, 2015 | 01:36 PM
Chrisinhouston's Avatar
As I recall you will have to first remove the finishers on either side of the windscreen. If they are original parts you may want to go ahead and replace them with new ones as the tabs underneath where metal mounting clips sit will often break off as all that black plastic gets brittle with age. Getting even new finishers back on is a challenge as you have to twist them hard and push them at just the right angle and hard enough to get the metal clips to stay in place. Typical LR engineering!
You will also have to remove the wipers and possibly have to loosen the mounting bolts for the hood to slide it forward a bit.
Old May 29, 2015 | 05:28 PM
Celto 4's Avatar
hi thanks got the finishers off no breakage used a paint stir stick and worked slow grill is out half way there!!
Old May 29, 2015 | 09:45 PM
Fallstaff's Avatar
I have to do the same. Every time I get a car wash the passenger side floor gets wet.
Let us know how it goes!
N.
Old May 31, 2015 | 10:25 AM
Celto 4's Avatar
Default cowl finisher
will do seems the best price ive found is Rovers North comes with all the fixins
Old May 31, 2015 | 11:38 AM
ralphobell's Avatar
That's the best price I have seen, if it is not fiberglass. I ordered a fiberglass one in the past and its not a perfect fit also the paint cracks and chips easily. I fixed that by plastidipping the cowl. Let us know how it goes. If the quality is good I'll order it from them for my future project.
Old May 31, 2015 | 12:07 PM
Celto 4's Avatar
hi from what i have been able to find out so far the fiberglass ones come out of Florida and you are right chip and dont fit well
Old Dec 23, 2024 | 06:03 PM
dmueller's Avatar
Hey @Alex_M — any chance you have a few photos of that ac intake cover? were you able to successfully solve w/o restricting airflow and putting strain on the fan? Thanks in advance!
Old Dec 26, 2024 | 12:46 AM
Tony Luna's Avatar
Check this out - https://landroverforums.com/forum/di...otwell-102055/
jwigum
Oct 25, 2018 10:31 AM
Celto 4
Aug 8, 2015 03:13 PM
Chrisinhouston
Aug 13, 2013 03:30 PM
ralphobell
Apr 1, 2013 11:09 AM
sayeedA
Aug 30, 2012 01:52 PM
