LR 2003 D2/SE headliner problem
Old Aug 17, 2013 | 04:04 PM
RALLENSBCA's Avatar
5th Gear
Default LR 2003 D2/SE headliner problem
New to this forum so thank you for the help.
I have a 2003 D2/SE7 and the headliner is separating and coming off the roof. Tried contact spray but does not hold. Lucky 8 told me to pull it all off, scarp off the yellow foam/glue and spray the headliner with some sort of plastic installation paint (was not specific). What have you done to correct the headliner problem?
Thanks
Richard
Old Aug 17, 2013 | 04:56 PM
EVN137's Avatar
Hi Richard,
First and foremost, welcome to the forum.
The info you need is under the section " Sticky - Write ups, How Tos, and Must Read "
" Interior " subsection DIi Headliner.
Regards,
Ed
Old Aug 19, 2013 | 10:38 PM
RALLENSBCA's Avatar
5th Gear
Thank you Ed for the info.
Old Aug 19, 2013 | 10:52 PM
dusty1's Avatar
welcome..my 2cents. do some forum searching before you tackle the headliner. there is a wealth of experience on the matter. I've seen recovers from kevlar to giraffe. I painted mine and love the way it looks, but it is all a matter of opinion. I exercised all methods to patch mine up, all proved futile. it is a do the whole thing deal, but quick and easy. took me about 3hrs. good luck in your endeavors.
Old Aug 19, 2013 | 11:01 PM
RALLENSBCA's Avatar
5th Gear
Thank you Dusty
Old Aug 20, 2013 | 06:58 AM
starcraft1's Avatar
I wasnt going to be bothered with removing the headliner. I bought these clips on amazon and spray painted them the color of my headliner (beige). I put them up all over the car in a uniform manner and they look like the normal interior body panel clips. One recommendation though is to use a sharp tool to poke a small hole in the fabric before using the clip. They are supposed to tear themselves through but it just coils up the fabric if you dont. good luck
Amazon.com: Dorman HELP! 74361 Headliner Retainer: Automotive Amazon.com: Dorman HELP! 74361 Headliner Retainer: Automotive
Old Aug 20, 2013 | 07:03 AM
drowssap's Avatar
I used old fashion thumb tacks, until it needs to come out
Old Aug 20, 2013 | 07:53 AM
ralphobell's Avatar
Another option, which I did was to remove the headliner and take it to a Headliner Shop. They only charged me $150 to put the new liner on. Normally the job is $350 but that is mostly labor to take out and reinstall the headliner.
Old Aug 20, 2013 | 08:32 AM
slabrat's Avatar
Got mine done at an upholstry place for $100. Sam as Ralphobell above. They did a great job and it looks nice Kind of a pain in the A$$ to put back in by yourself, Recruit some unsuspecting help.
Spouses and close friends usually excluded.
jrkstore43
Feb 9, 2012 01:33 PM
2003Disco2
Jul 25, 2006 06:45 PM
2003Disco2
Jun 28, 2006 03:57 AM
LarDog44
Jun 26, 2006 11:39 PM
DiscoGirl
Jul 28, 2005 01:49 PM
