LR D2 MAF Sensor Recommendations
Old 10-02-2020, 02:52 PM
austinlandroverbill's Avatar
Default LR D2 MAF Sensor Recommendations
Anyone have a recommendation for a MAF sensor.
Should I "bite the bullet" and go with the OEM Bosch or use a different (read cheaper) manufacturer.
FYI, I have a 4.6HSE with secondary air (that's what the air injection system is called, right) so the intake and throttle throats on the MAF body are a little bigger (~4mm) than non-SA motors, right?
Searched the forum but did didn't get any results in spite of this being a common maintenance part (right?).
And should I buy just the sensor or the whole body?
Old 10-02-2020, 04:14 PM
arains44's Avatar
@austinlandroverbill I would 100% recommend getting the Bosch part. I bought a used MAF and ended up being bad, threw a check engine light etc. Bought the Bosch MAF and have been good to go.
I think most folks will tell you that D2's really like the Bosch parts. Seems like it's worth buying the right stuff.
I bough the whole MAF assembly off of parts geek for $130 or so. Best price I found on genuine Bosch. You can buy just the sensor, but you will need the right tool to pull it out.
Old 10-02-2020, 05:31 PM
Best4x4's Avatar
Received 2,297 Likes on 1,688 Posts
I've installed several Delphi MAF sensors for customers without any issues. It will come with new screws and a bit to remove the old one as well.
Old 10-02-2020, 06:59 PM
Thanks.
I pulled the sensor and cleaned it already, so no biggie there -- used a security bit set from Harbor freight, worked fine.
Again, my worry is that if I buy an MAF sensor + body, I may get the slightly smaller one for non-secondary air vehicles that wont fit the airbox or throttle body ends.
Any Bosch part number for a secondary air equipped 4.6 HSE?
Old 10-02-2020, 08:15 PM
Best4x4's Avatar
I save $$$ and get the sensor itself as they're identical between a 4.0/4.6L engine. The difference = the housing itself.
Wheelspin (10-03-2020)
Old 10-03-2020, 03:12 AM
JUKE179r's Avatar
@Best4x4 is right. I think our same MAF sensor itself fits a few Audis, VWs, Minis and BMWs but at a cheaper price.
Old 10-03-2020, 05:59 AM
arains44's Avatar
To @Best4x4 ’s point, I’ve heard the same about the Delphi Sensor.
Also, now that’s it’s mentioned, I think I bought a MAF for a BMW that is the exact same let as the D2 part. I’d have to go back and look, but I believe there’s another vehicle out there with the same exact sensor and housing.
Old 10-03-2020, 07:40 AM
JUKE179r, can you point me to a part number?
And do I have it right about the secondary air injection engines have a slightly larger diameter MAF?
Old 10-03-2020, 08:06 AM
mln01's Avatar
I think the different diameters are '99-'02 vs. '03-'04, not SAI vs. non-SAI.
Old 10-03-2020, 03:33 PM
rhyslegge's Avatar
For what it's worth, I stumbled across some info on Tornado Systems website, the guys in the UK who do re-mapping of the V8 ecu. They recommend changing the MAF after 80-90k and say that the ECU is sensitive to the original Bosch part (MAF) if a re-mapped ECU is used. I have a stock ECU, so I have no experience with this, just found it interesting to consider. I can't find a history item for my '00 saying the MAF was ever changed, so i believe mine is original @ 160k miles. I can see the desire to go aftermarket with this part tho, the price difference between it and the Bosch part is pretty big.
Rhys L.
Quick Reply: LR D2 MAF Sensor Recommendations
