LR Diesel 98 - Internal Electrics
Old May 19, 2008 | 04:17 AM
Byte's Avatar
5th Gear
Default LR Diesel 98 - Internal Electrics
Team,
Every time my mate's LR drives over large bumps, both his blinkers turn on and automatic door lock mechanism engages (without locking).
Help me diagonose this problem.
Cam
Old May 19, 2008 | 07:34 AM
Default RE: LR Diesel 98 - Internal Electrics
He has a door latch out of adjustment. The blinkers are flashing because they think that he is locking the door, same with his locks.
If it isint the latch then it is one of the buttons that turn the interior lights on and off when you open the door. You know, that button on the door jam. The one that is like the button in your fridge.
One of those two things is out of adjustment, the button might just need to be replaced.
Old May 19, 2008 | 08:54 PM
Byte's Avatar
5th Gear
Thanks SPike.
Would a loose fuse also cause this problem?
Cam
Old May 19, 2008 | 08:57 PM
Maybe. Check that first, I didnt think about that.
Old May 19, 2008 | 10:08 PM
llesra's Avatar
he must be setting off the inertia switch. the car thinks youve been in an accident and unlocks the doors and activates the blinkers. this is a very common occurance. you reset this by restarting the car.
Old May 20, 2008 | 08:23 PM
Byte's Avatar
5th Gear
thanks guys - great repsonses
wexford v8
Jul 9, 2009 04:59 PM
rwarren92
Engine & Internal
Apr 28, 2008 09:15 PM
gsgtsg
Feb 28, 2008 06:36 PM
alanroberts50
Nov 21, 2007 08:48 PM
edbar
Jan 1, 2005 09:08 AM
