LS swap
Old Jun 29, 2021 | 11:43 PM
dwilshire_22's Avatar
8th Gear
Default LS swap
I know ACE (Alternative Conversions) is the most predominant for the LS swap kit. But they have a 10 week wait right now and I'd rather not wait that long as I am borrowing a car since the damned disco blew up. Is there any other companies that make and sell what ACE does? Even if they were a little more expensive. I can't seem to find everything separately that they sell. Links would be very helpful! Or if I could do any other engine swap for under 10k USD I would be open to that. My shop told me any swap would be $1750 so any suggestions would be great.
Thanks, Dalton
Old Jun 30, 2021 | 06:33 AM
mollusc's Avatar
Pretty sure there's a whole subforum on engine swaps, including discussions about several options for LS engines.
Old Jun 30, 2021 | 11:09 AM
CaptainAaron's Avatar
About 90-95% of the ACE swap kit is custom made parts. The ACE parts aren’t available elsewhere. It would be difficult and time consuming to piece together and fabricate your own kit from different stuff (a lot longer than 10 weeks). I would not attempt this unless you know how to fabricate and spend the time to work out the electrical.
There are other options for transmissions, but it will take significantly more fabrication and work to make those fit. And the price will go up substantially.
Since it sounds like you are limited on time, I would probably recommend either waiting for the kit, or putting in a used Land Rover 4.0 to hold you over until you have time to do the swap. Furthermore, I would be wary of a shop putting a flat rate of less than $2000 on any non-factory engine swap. An engine swap done right, even with a kit, is a significant time investment.
Old Jun 30, 2021 | 01:44 PM
whowa004's Avatar
You can buy motor mounts and use a gm trans and there is an adapter to the LT230. This is going to involve a lot more time as it's not as simple to get the electronics to play nice for full dash functionality. I can tell you that the shop near me that does incredible work you aren't getting an LS swap done for under 15K in labor and thats in classics and D1s which is much simpler to do. Aaron has the right idea, even with the ACE kit it's not going to be a week or two week endeavor.
Old Jun 30, 2021 | 02:25 PM
redwhitekat's Avatar
buy a ready to go block from atlantic british slap the heads on and go for another 200,000 miles
Luckyjayb
Nov 2, 2017 07:51 PM
ekahi_1
Nov 16, 2012 09:14 PM
98HSE46
Nov 4, 2012 04:49 PM
Spencerfitch
Feb 14, 2011 12:47 AM
03discoman
Dec 18, 2009 09:29 PM
