LT230 Flange Self Locking Nyloc Nuts
Old Apr 6, 2018 | 05:44 AM
OffroadFrance's Avatar
Default LT230 Flange Self Locking Nyloc Nuts
Hi
LT230SE Transfer gearbox
Does anyone know the thread size/type of the output flanges shafts, thread sizes of the front and rear output shafts and also the AF metric spanner size/socket size needed.
Many thanks
Old Apr 6, 2018 | 07:33 AM
Best4x4's Avatar
9/16 open end wrench/socket works best for me without rounding off the nuts. As far as the thread I'm not sure. On the last D2 I worked on the bolts on the front flange were totally trashed so I removed the giant C-Clip and replaced the bolts and nuts completely.
Old Apr 6, 2018 | 12:05 PM
OverRover's Avatar
Originally Posted by OffroadFrance
Hi
Many thanks
1. M20, IDK the pitch. Same NyLoc Nut front/rear Part #: NY120041L
2. NyLoc Nuts are the same front/rear Part #NZ606041L > 3/8" UNF
3. Spanner is 9/16", I find an open end/box wrench to work well too. The "prop shaft tool" can also be useful.
Old Apr 6, 2018 | 05:20 PM
Thanks you guys, it's the M20 shaft bolt I am interested in as I have the 1/2" drive special tool for the 4# flange bolts. The M20 ID is good for me though as I'm making a slide hammer tool to remove the front output bearing complete with the shaft as the bearing is a bit slack and moving circa 0.010" up and down. I think some torch heat may be required also to warm the transfer casing. I'll be doing a total LT230 rebuild sometime soon.
Thanks Over Rover and Best4x4 it's useful info.
Old Apr 6, 2018 | 05:45 PM
Best4x4's Avatar
No problem!
wynhd
Mar 17, 2017 01:49 PM
fishEH
Aug 24, 2016 06:58 PM
Dan7
May 7, 2014 01:07 PM
dcarr1971
Feb 8, 2013 08:16 AM
johanba
Apr 3, 2007 11:37 AM
