LT230 rear output seal woes
Old Mar 2, 2024 | 06:14 PM
losinov's Avatar
Default LT230 rear output seal woes
FYI - I mistitled this post. It's the front output seal not the rear.
Hey all, I recently replaced the front output seal and flange on my transfer case and still had a leak a few days later. Although this time I noticed metal flakes in the gear oil.
After taking it apart again I saw that the black mud shield of the flange wasn’t sitting evenly within the transfer case and cut into the inner wall that it presses up against. I believe the oil seal sits behind this groove and should still seal properly.
I assume I shouldn’t use the same flange as it looks like the black part is no longer straight. Any recommendations on what to do about the groove on the inner wall?
I’m guessing this is a result of the seal not going in completely squarely?
here’s a link to some higher res images
https://imgur.com/a/ZFLl53x
Richard Gallant
Mar 4, 2022 04:54 PM
frostythor
May 5, 2020 02:12 PM
rsvrman
Jul 10, 2019 12:20 AM
damygoliath
Sep 30, 2013 10:52 AM
ATXDisco
Aug 12, 2011 06:10 AM
