Lubricated rear hub today...
Old May 20, 2015 | 05:36 PM
Externet's Avatar
Default Lubricated rear hub today...
Hi. Took considerable amount of grease, somewhere around 2 cubic inches. All went well.
Removed wheel,
Separated sensor wire from clips,
Removed two 13mm - 12 point bolts holding the caliper bracket from hub,
Pulled the whole caliper assembly without disturbing pads,
Removed disc,
Removed speed sensor and o-ring,
Fed grease with hand pump until overflowed by the outer hub seal, with a plastic tip from a silicone dispenser, cut to fit :
----> Common Grease Gun Photo by Innernet | Photobucket
Perhaps will help someone.
Old May 20, 2015 | 06:59 PM
ls1morethanyou's Avatar
was this for a three amigo fix or just a tune up? i did it once and it didnt work as a three amigo fix.
Old May 20, 2015 | 08:00 PM
Externet's Avatar
Just preventive maintenance.
For the three amigos -sensor related- I hook an oscilloscope by the ABS computer input connector to monitor the senders correct waveform presence or not. No tail chasing that way.
Grease or lack of it should not impair a healthy sensor signal.
Edited: Done with the other side. Road tested. Smooth and very quiet. Am happy.
lipadj46
Jun 1, 2009 09:47 AM
wvujosh
Sep 30, 2007 11:40 AM
01 Discovery
Dec 1, 2006 12:07 AM
Tanrover
Nov 20, 2006 11:30 AM
masonstewart
Jul 17, 2006 02:32 PM
