Lucas Oil Super Coolant
Mike I found a Motorad 439-180 degree soft spring t/stat on Amazon for about $36.00, I take it that is the correct t/stat. I live in the south now and some days the engine temp is over 212 F. If the and the super coolant will lower it by 10 then Im a happy guy.
Ths stat will make the most difference, the "wetting agent" (reduces the size of gas bubbles formed by heating inside engine) will also help, but can't get temps below the threshold of the mechanical stat. So if you are running 212, and a new stat drops that to 185, don't expect the water treatment to drop that another 10 degrees, etc.
http://www.bgprod.com/distloc.html this will help anyone trying to locate this Awesome product! This product was not sold at any auto part stores in my area. I found it at independent shops that use there products. Works great!
Hope this makes your search easier folks:-)
