lug nut size?
Old Sep 28, 2011 | 11:57 AM
dgi 07's Avatar
Default lug nut size?
Title says it all, anyone know what size our standard lugs are.......?
Old Sep 28, 2011 | 12:07 PM
russburcham's Avatar
27mm I believe
Old Sep 28, 2011 | 12:34 PM
dgi 07's Avatar
thanks for the quick response..
no offense but can i get a confirmation?
Old Sep 28, 2011 | 12:36 PM
moncton_vw's Avatar
Yup, they are 27mm
Old Sep 28, 2011 | 12:44 PM
dgi 07's Avatar
thank you both. You are both scholars and gentlemen.!
Old Sep 28, 2011 | 01:21 PM
And they don't swap between d1 and d2, different size studs. At least on the ones I tried to snag because mine were so beat up. later I found out "why" they get beat up....
Old Sep 28, 2011 | 01:50 PM
dgi 07's Avatar
and thank you kind sir....you i completely understand why they get beat up......whoever owned my truck before me had someone install the wheels with an airgun.......a really, really big airgun .....so i figured I'd bring home some toolage from work.
Old Sep 28, 2011 | 09:22 PM
buick215's Avatar
1 1/16 6 point socket is actually the correct size but you can use a 27 mm socket without any problems.
Old Sep 28, 2011 | 09:45 PM
cipher982's Avatar
I've used the same 1" 1/16 socket on both DI and DII
Old Sep 29, 2011 | 09:09 AM
Why don't you go back to the shop that screwed up and have them replace all the lug nuts. I did 7 or 8 years ago when a shop used the wrong size socket and deformed my tin covers, got a complete new set on them.
