Lug nut size
Old Feb 7, 2013 | 11:10 AM
MC04DII's Avatar
Default Lug nut size
I'm putting on a lift this weekend, but I can't get the lug nuts off with the supplied lug wrench. I will need to use an impact. What size socket fits the stock lug nuts? Thanks.
Old Feb 7, 2013 | 11:23 AM
ZGPhoto's Avatar
Do not use an impact to break tension. Break tension with a wrench and then use the impact. The reason you can't fit the supplied lug wrench is because someone used an impact and ruined the alloy party wrapper.
Old Feb 7, 2013 | 11:56 AM
I agree, do not you an impact gun, you will distort the tin covers.
Use a 24" breaker bar and a 1 1/16th 6 point socket.
Old Feb 7, 2013 | 11:59 AM
MC04DII's Avatar
Ok, I'll do that. Thanks
Old Feb 7, 2013 | 01:02 PM
Paul Grant's Avatar
27mm or 1 1/16th is the socket size when they're new. I often have to use a 1 1/8th socket to remove severely distorted lug nuts. It they are so bad that that size won't work, I then peel the alloy away from the steel lug underneath and pound a 25 or 26mm socket on.
Classic89
Apr 22, 2020 03:05 PM
KneeDragger10
Nov 19, 2013 10:33 AM
dgi 07
Jul 19, 2012 10:39 AM
Rover Chris
Oct 3, 2009 04:22 PM
LRDISCO
Dec 10, 2007 06:16 PM
