Lynx diagnostics bleeding procedure
I have the BritPart Lynx diagnostics system.
I tried using the system to bleed the brakes but I am befuddled by the brake bleeding functionality that comes with the Lynx system. When the bleeding procedure begins it starts the ABS module for each wheel in succession. Left front, right front, left rear, right rear and each cycling of the wheel bleeding take no more than a second or two for each wheel, hardly enough time to open the bleed nipple bleed the brakes then close the nipple.
Am I missing something here? It would take five guys to bleed brakes using this software. one guy on each wheel and one guy operating the software.
Without seeing the Lynx procedure it's hard to comment but the norm is 10 seconds per wheel so it maybe a misprint. Look at the earlier post on here about bleeding brakes with TC and ABS and it gives the Nanocom, RAVE and WABCO procedures altogether. I would tend to clarify with Lynx or failing that extrapolate the timeline from the other procedures.
Do you have a link to the post on here about bleeding brakes with TC and ABS?
...................... fortunately I only reside in France............. for the time being..................... then back to Blighty or maybe the US.............
ssblast20
Feb 25, 2012 07:55 AM
03discoman
Apr 22, 2010 10:07 PM
