Britpart Lynx diagnostic questions (guinea pig)
Old Aug 6, 2015 | 10:21 PM
me6067's Avatar
Default Britpart Lynx diagnostic questions (guinea pig)
Hi guys,
I recently got the Britpart Lynx Diagnostic system for my D2... I am still learning to play around with it and seeing what it can do. If anyone has any questions or wants me to see if the system has certain capabilities I would be more then willing to try to help people figure out if this is the right diagnostic tool for them before they buy. I am sure you have figured out that Britpart has very limited information about their tools capabilities.
Cheers
Old Jan 24, 2017 | 09:23 AM
WarrenZ's Avatar
I would love to hear what kind of luck you've had with the unit in regards to its purported programming abilities: https://landroverforums.com/forum/ge...ailures-82623/
My experience has been that I can't access the unit's programming functions without some unknown 18-digit code that neither Britpart nor Land Rover can identify.
Old Jan 24, 2017 | 09:43 AM
me6067's Avatar
I haven't had much trouble with my lynx and have successfully been able to re-program old keys to my truck. I used the spreadsheet code generator people talked about on a another thread back in the past to generate the 18 digit code from the small code on the inside of the key. https://docs.google.com/spreadsheets...uyU/edit#gid=0
Other then that I have tried to re-program my fog lamps to be able to stay on while having my high beams on but it's as if the settings wont save to the bcm. Maybe I am not doing it right... This said I haven't had to use it much other then that.
Old Jan 24, 2017 | 09:59 AM
WarrenZ's Avatar
Thanks. I hadn't found that spreadsheet. I'll give it a look, but it looks like it's still providing a 16-digit code instead of an 18-digit. I'll read it more closely, thought. thanks again.
Old Jan 24, 2017 | 10:02 AM
me6067's Avatar
The "*" at the beginning and end of the string of numbers counts as a digit. I also had to figure this out the hard way my first time.
Old Jan 24, 2017 | 10:08 AM
WarrenZ's Avatar
awesome - thank you! Britpart should send you a fee.
Nitrojunkie383
Build Threads
81
Jun 24, 2020 12:42 AM
chicane
Jul 15, 2014 10:32 AM
kaisermhw
Oct 16, 2013 08:39 PM
geek_IM
Sep 18, 2010 07:43 PM
Paul64
May 22, 2007 01:07 PM
