M & S lights flashing
Old Oct 26, 2011 | 12:24 AM
  #21
buick215's Avatar
Mine has no slash thru the D on the dash but it does flash along with the M & S lights. As for the transmission I had it serviced around 15,000 miles ago, along with all of the other 60,000 mile requirements.
Old Jan 11, 2012 | 06:49 PM
  #22
Dave03S's Avatar
I just had the flashing M & S lights and D (limp mode)... upon inspection found my Interstate battery was the original to the truck last hole punched being 2002!
Found an online deal at Firestone for the exact same battery for 79.99 + fees and taxes. no brainer.
new battery put the lights back to normal and as a bonus a few other minor issues went away. I was having what seemed like the tranny shifting later than it should intermittently... hasn't happened since the new battery, and I have no explanation but the truck seems to run smoother and stronger too.
Old Jan 11, 2012 | 08:32 PM
  #23
buick215's Avatar
Yes, sometimes the cause is a weak battery but in my case the battery is fairly new and was checked out and found to be ok.
Old Jan 11, 2012 | 09:48 PM
  #24
Dave03S:
from the RAVE shop manual about the tranny ECU
P1562 * Battery supply below 9V while engine running
Maintains current gear in low range, limp home mode in range. Shift pressure to
maximum, harsh gear shifts/engagement.
Check engine light = Off
M&S Light = On
Sounds like your new battery was just what the doctor ordered. The electronic transmission detects the wimpy battery before the radio goes dead....
Old Jan 13, 2012 | 11:28 PM
  #25
Mr. Clean's Avatar
Originally Posted by hilltoppersx
sounds like the xyz is bad. u live in florida. my guess is you use the air con often. the drain drips directly on the xyz. so unless they rerouted the drain out very well could have failed again. it can be rebuilt. it's a mechanical switch. it fills with water and contacts become soiled.
What is the XYZ? And where is it located?
Old Jan 14, 2012 | 08:50 AM
  #26
Driver's side of transmission. Where a design issue allows AC condensate drain to keep in wet. Muck builds up inside. Can be removed, rivits drilled out, cleaned up, etc. It has a series of metal switch contacts that tell the tranny ECU what selection you have commanded.
Old Jan 15, 2012 | 12:10 PM
  #27
Mr. Clean's Avatar
Thank you for the info... Sounds like AKA, "Neutral Safety Switch".
Old Jan 8, 2020 | 10:13 PM
  #28
Carlos Man's Avatar
Originally Posted by dino109
It is most likely NOT the XYZ switch.
A blinking M and S light alone will indicate low voltage / battery under proper voltage. The condition may be intermittent.
Replace or have your alternator and battery tested.
IF it is the XYZ switch failing as a result of drainage from the AC drains, the gear display will also show a capital D with a slash through it, and it will also be flashing in conjunction with the M and S lights.
Don't replace the XYZ switch if you don't have to. This is just from my personal experiences with the same flashing lights.
my rover just had those three indicators blinking.... can you explain what needs to be done?
Old Jan 8, 2020 | 10:15 PM
  #29
Carlos Man's Avatar
what was your outcome ... I just got this issue (no slash)
Old Jan 9, 2020 | 04:04 AM
  #30
JUKE179r's Avatar
@Carlos Man … you need to get the trouble codes read with a diagnostic tester preferably a dedicated Land Rover tester. If not, it's a guessing game to find the source of the problem.
Post your fault codes on your other post.
