M+S lights flashing P0705/ other issues.
Old 12-12-2019, 04:58 AM
8wr_zj's Avatar
7th Gear
Ok so i am thinking that the pump or the torques converter were not installed correctly by the PO. The PO replace a leaking o-ring behind the pump. During the reinstall of the transmission the cps wiring was smashed. I drained the trans fluid and removed the pan hoping to find a broken standpipe or something like that. however everything looked great inside. After I refilled to the correct level. I removed the bottom transmission line and started the rover. I placed the transmission in park and no fluid came out for the 30 to 45 seconds i let the rover run. What do yall think see above post i can get it to move around the yard but i have to rev it to 3k and use low on t-case.
Meldav32
02-23-2022 06:53 PM
bcolins
11-19-2019 12:59 PM
meltdowndave
11-05-2019 09:02 PM
sickws6
01-10-2018 02:33 AM
boldingm
05-16-2011 04:59 PM
Quick Reply: M+S lights flashing P0705/ other issues.
